So weit alles verstanden, jetzt hoffe ich, dass ich das in der richtigen Form hochgeladen kriege
Falls das so doof Ost, einfach nochmal sagen. Danke schon mal!
EtreCheckPro version: 6.6 (66014)
Report generated: 2022-06-02 08:50:02
Download EtreCheckPro from https://etrecheck.com
Runtime: 3:28
Performance: Excellent
Problem: Other problem
Description:
All programs are closed after sleep mode.
Major Issues:
Anything that appears on this list needs immediate attention.
Time Machine backup out-of-date - The last Time Machine backup is over 10 days old.
Low disk space - This computer is running critically low on free hard drive space.
Minor Issues:
These issues do not need immediate attention but they may indicate future problems or opportunities for improvement.
SSD too slow - SSD is showing poor performance.
Time Machine auto backup disabled - Time Machine auto backups are disabled.
Heavy RAM usage - Apps are using a large amount of RAM.
Clean up - There are orphan files that could be removed.
Unsigned files - There are unsigned software files installed. These files could be old, incompatible, and cause problems. They should be reviewed.
System modifications - There are a large number of system modifications running in the background.
x86-only Apps - This computer has x86-only apps might not work on future versions of the operating system.
Kernel extensions present - This computer has kernel extensions that may not work in the future.
Sharing enabled - This computer has sharing services enabled that could be a security risk.
Hardware Information:
MacBook Pro (15-inch, 2018)
MacBook Pro Model: MacBookPro15,1
2,6 GHz 6-Core Intel Core i7 (i7-8850H) CPU: 6-core
16 GB RAM - Not upgradeable
BANK 0/ChannelA-DIMM0 - 8 GB DDR4 2400
BANK 2/ChannelB-DIMM0 - 8 GB DDR4 2400
Battery: Health = Normal - Cycle count = 302
Video Information:
Intel UHD Graphics 630 - VRAM: 1536 MB
Color LCD (built-in) 3360 x 2100
Radeon Pro 560X - VRAM: 4 GB
Drives:
disk0 - APPLE SSD AP0512M 500.28 GB (Solid State - TRIM: Yes)
Internal PCI-Express 8.0 GT/s x4 NVM Express
disk0s1 - EFI [EFI] 315 MB
disk0s2 [APFS Container] 499.96 GB
disk1 [APFS Virtual drive] 499.96 GB (Shared by 6 volumes)
disk1s1 - M*******************n (APFS) [APFS Virtual drive] (Shared - 462.98 GB used)
disk1s2 - Preboot (APFS) [APFS Preboot] (Shared - 663 MB used)
disk1s3 - Recovery (APFS) [Recovery] (Shared - 1.11 GB used)
disk1s4 - VM (APFS) [APFS VM] (Shared - 5.37 GB used)
disk1s5 (APFS) [APFS Container] (Shared - 23.57 GB used)
disk1s5s1 - M***********D (APFS) [APFS Snapshot] (Shared - 23.57 GB used)
disk1s6 - Update (APFS) (Shared - 108 MB used)
disk2 - Lexar USB Flash Drive 32.08 GB
External USB 5 Gbit/s USB
disk2s1 - L***r (MS-DOS FAT32) 32.02 GB (17.62 GB used)
Mounted Volumes:
disk1s1 - M*******************n [APFS Virtual drive]
499.96 GB (Shared - 462.98 GB used, 5.99 GB free)
APFS
Mount point: /System/Volumes/Data
Encrypted
disk1s2 - Preboot [APFS Preboot]
499.96 GB (Shared - 663 MB used, 5.99 GB free)
APFS
Mount point: /System/Volumes/Preboot
disk1s4 - VM [APFS VM]
499.96 GB (Shared - 5.37 GB used, 5.99 GB free)
APFS
Mount point: /System/Volumes/VM
disk1s5 [APFS Container]
499.96 GB (Shared - 23.57 GB used, 5.99 GB free)
APFS
Mount point: /System/Volumes/Update/mnt1
Encrypted
Partitions:
disk1s5s1
disk1s5s1 - M***********D [APFS Snapshot]
APFS
Mount point: /
Read-only: Yes
disk1s6 - Update
499.96 GB (Shared - 108 MB used, 5.99 GB free)
APFS
disk2s1 - L***r
32.02 GB (17.62 GB used, 14.40 GB free)
MS-DOS FAT32
Mount point: /Volumes/L***r
Network:
Interface SAMSUNG_MDM: SAMSUNG Modem
Interface en7: USB 10/100/1000 LAN
Interface en0: Wi-Fi
802.11 a/b/g/n/ac
Interface bridge0: Thunderbolt Bridge
Interface bridge0: Thunderbolt Bridge 2
Printer sharing: Enabled
System Software:
macOS Monterey 12.3.1 (21E258)
Time since boot: About 14 days
Notifications:
Firefox.app
2 notifications
Security:
Gatekeeper: App Store and identified developers
System Integrity Protection: Enabled
Antivirus software: Apple
Unsigned Files:
Launchd: /Library/LaunchDaemons/com.microsoft.office.licensing.helper.plist
Executable: /Library/PrivilegedHelperTools/com.microsoft.office.licensing.helper
Details: Exact match found in the legitimate list - probably OK
Running app: /Applications/Sherpa.app/Contents/MacOS/Sherpa
Login Item: /Applications/Sherpa.app
Login Item: ~/Library/Application Support/.FUS/fuspredownloader.app
Plugin: /Library/Internet Plug-Ins/SharePointBrowserPlugin.plugin
Plugin: /Library/Internet Plug-Ins/Silverlight.plugin
Plugin: /Library/CoreMediaIO/Plug-Ins/DAL/iGlasses.plugin
Apps: 5
Old Applications:
30 x86-only apps
Kernel Extensions:
/Applications/Smart Switch/SmartSwitch.app
[Not Loaded] ssuddrv.kext - com.devguru.driver.SamsungComposite (DEVGURU Co., Ltd., 1.4.45 - SDK 10.6)
/Applications/Wondershare Filmora9.app
[Not Loaded] SystemAudioRecorder.kext - com.Perfect.Driver.SystemAudioRecorder (Wondershare Software Co., Ltd, 1.1.0 - SDK 10.9)
System Launch Daemons:
[Not Loaded] 37 Apple tasks
[Loaded] 173 Apple tasks
[Running] 170 Apple tasks
[Other] One Apple task
System Launch Agents:
[Not Loaded] 16 Apple tasks
[Loaded] 163 Apple tasks
[Running] 177 Apple tasks
Launch Daemons:
[Not Loaded] com.apple.installer.osmessagetracing.plist (Apple - installed 2020-06-02)
[Running] com.foxit.PDFReaderUpdateService.plist (Foxit Corporation - installed 2021-09-24)
[Loaded] com.google.keystone.daemon.plist (Google LLC - installed 2022-04-19)
[Running] com.microsoft.OneDriveStandaloneUpdaterDaemon.plist (Microsoft Corporation - installed 2021-07-29)
[Loaded] com.microsoft.OneDriveUpdaterDaemon.plist (Microsoft Corporation - installed 2021-07-29)
[Loaded] com.microsoft.autoupdate.helper.plist (Microsoft Corporation - installed 2021-07-28)
[Loaded] com.microsoft.office.licensing.helper.plist (Not signed - installed 2020-08-26)
[Loaded] com.microsoft.office.licensingV2.helper.plist (Microsoft Corporation - installed 2020-11-15)
[Loaded] com.teamviewer.Helper.plist (TeamViewer GmbH - installed 2021-12-15)
[Not Loaded] com.teamviewer.teamviewer_service.plist (TeamViewer GmbH - installed 2021-12-12)
[Running] de.devolo.networkservice.plist (devolo AG - installed 2022-02-05)
[Loaded] us.zoom.ZoomDaemon.plist (Zoom Video Communications, Inc. - installed 2022-05-09)
Launch Agents:
[Running] com.brother.LOGINserver.plist (Brother Industries, LTD. - installed 2019-09-02)
[Running] com.ecamm.iglasses3agent.plist (Ecamm Network, LLC - installed 2020-05-20)
[Loaded] com.google.keystone.agent.plist (Google LLC - installed 2022-04-19)
[Loaded] com.google.keystone.xpcservice.plist (Google LLC - installed 2022-04-19)
[Loaded] com.microsoft.OneDriveStandaloneUpdater.plist (Microsoft Corporation - installed 2021-07-29)
[Loaded] com.microsoft.update.agent.plist (Microsoft Corporation - installed 2021-07-28)
[Not Loaded] com.teamviewer.teamviewer.plist (TeamViewer GmbH - installed 2021-12-12)
[Not Loaded] com.teamviewer.teamviewer_desktop.plist (TeamViewer GmbH - installed 2021-12-12)
[Loaded] de.devolo.networkservice.notify.plist (devolo AG - installed 2022-02-05)
User Launch Agents:
[Loaded] com.logmein.GoToMeeting.G2MAIRUploader.plist (LogMeIn, Inc. - installed 2020-11-26)
[Loaded] com.logmein.GoToMeeting.G2MUpdate.plist (LogMeIn, Inc. - installed 2020-11-26)
[Other] com.seagate.toolkit.plist (Not signed - installed 2019-07-11)
[Running] com.spotify.webhelper.plist (Spotify - installed 2022-05-19)
User Login Items:
[Running] App Cleaner Helper (Sergiy Savenko - installed 2019-08-28)
Modern Login Item
/Applications/App Cleaner.app/Contents/Library/LoginItems/App Cleaner Helper.app
[Running] MagentaCLOUD LaunchHelper (Telekom Deutschland GmbH - installed 2021-01-15)
Modern Login Item
/Applications/MagentaCLOUD.app/Contents/Library/LoginItems/MagentaCLOUD-LaunchHelper.app
[Not Loaded] Launcher Disabler (Microsoft Corporation - installed 2021-07-29)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/Launcher Disabler.app
[Not Loaded] OneDrive Launcher (Microsoft Corporation - installed 2021-07-29)
Modern Login Item
/Applications/OneDrive.app/Contents/Library/LoginItems/OneDrive Launcher.app
[Not Loaded] Rocket.Chat Login Helper (App Store - installed 2022-04-16)
Modern Login Item
/Applications/Rocket.Chat.app/Contents/Library/LoginItems/Rocket.Chat Login Helper.app
[Running] Sherpa (Not signed - installed 2022-06-01)
Application
[Running] Signal (Quiet Riddle Ventures LLC - installed 2022-05-18)
Application
/Applications/Signal.app
[Loaded] StartUpHelper (Spotify - installed 2018-05-04)
Modern Login Item
/Applications/Spotify.app/Contents/Library/LoginItems/StartUpHelper.app
[Loaded] fuspredownloader (Not signed - installed 2018-04-13)
Application
Internet Plug-ins:
SharePointBrowserPlugin: 14.0.0 (? - installed 2017-11-17)
Silverlight: 5.1.50901.0 (? - installed 2018-10-22)
Audio Plug-ins:
TVRemoteAudio: 1.0.1 (TeamViewer GmbH - installed 2021-12-12)
CoreMediaIO Plug-ins:
iGlasses: 3.5.2 (? - installed 2020-05-20)
3rd Party Preference Panes:
Toolkit (Seagate Technologies LLC - installed 2020-08-26)
Backup:
Skip System Files: No
Auto backup: No
Destinations:
T******r [Local] (Last used)
Total size: 999.86 GB
Total number of backups: 22
Oldest backup: 2020-09-06 18:10:55
Last backup: 2022-04-16 10:10:09
One local snapshot
Oldest local snapshot: 2022-04-16 10:03:26
Last local snapshot: 2022-04-16 10:03:26
Performance:
System Load: 2.72 (1 min ago) 3.35 (5 min ago) 3.25 (15 min ago)
Nominal I/O speed: 10.72 MB/s
File system: 20.88 seconds
Write speed: 299 MB/s
Read speed: 1779 MB/s
CPU Usage Snapshot:
Type Overall
System: 3 %
User: 5 %
Idle: 92 %
Top Processes Snapshot by CPU:
Process (count) CPU (
Source -
Location)
EtreCheckPro 18.04 % (Etresoft, Inc.)
FoxitPDFReaderUpdateService 17.22 % (Foxit Corporation)
WindowServer 9.18 % (Apple)
Google Chrome Helper (Renderer) (49) 3.70 % (Google LLC)
kernel_task 3.48 % (Apple)
Top Processes Snapshot by Memory:
Process (count) RAM usage (
Source -
Location)
Google Chrome Helper (Renderer) (49) 2.95 GB (Google LLC)
com.apple.WebKit.WebContent (29) 2.10 GB (Apple)
EtreCheckPro 680 MB (Etresoft, Inc.)
kernel_task 390 MB (Apple)
MTLCompilerService (40) 355 MB (Apple)
Top Processes Snapshot by Network Use:
Process Input /
Output (
Source -
Location)
bosUpdateProxy 506 KB / 490 MB (Apple)
mDNSResponder 30 MB / 20 MB (Apple)
Mail 3 MB / 198 KB (Apple)
remoted 952 KB / 1 MB (Apple)
com.apple.WebKit.Networking 257 KB / 105 KB (Apple)
Top Processes Snapshot by Energy Use:
Process (count) Energy (0-100) (
Source -
Location)
FoxitPDFReaderUpdateService 7 (Foxit Corporation)
WindowServer 3 (Apple)
deleted (2) 2 (Apple)
coreduetd 2 (Apple)
Signal Helper (Renderer) 1 (Quiet Riddle Ventures LLC)
Virtual Memory Information:
Physical RAM: 16 GB
Free RAM: 36 MB
Used RAM: 12.15 GB
Cached files: 3.81 GB
Available RAM: 3.85 GB
Swap Used: 4.15 GB
Software Installs (past 60 days):
Install Date Name (
Version)
2022-04-15 macOS 12.3.1 (12.3.1)
2022-04-16 Rocket.Chat (3.8.4)
2022-04-23 Brother iPrint&Scan (10.2.0)
2022-04-29 MRTConfigData (1.93)
2022-05-09 Zoom (5.10.4.6592)
2022-05-13 XProtectPlistConfigData (2159)
2022-05-25 iMovie (10.3.3)
2022-06-01 Google Earth (1.3.17.192)
Clean up:
~/Library/LaunchAgents/com.seagate.toolkit.plist
/Applications/Toolkit.app/Contents/MacOS/Toolkit
Executable not found
Diagnostics Information (past 7-30 days):
2022-05-27 15:35:25 com.apple.WebKit.WebContent - High CPU Use
Executable: /System/Library/Frameworks/WebKit.framework/Versions/A/XPCServices/com.apple.WebKit.WebContent.xpc/Contents/MacOS/com.apple.WebKit.WebContent
End of report
