Das muss man doch nicht sagen... das sollte doch schon Dir beim Erstellen logisch erscheinen, dass sowas nicht gut ist. Das sagt mir doch die gesunde Menschen Logik - oder?Da kann ma ganz normal sagen he mach nächstes mal nur einen Thread auf und schau dir alle Ordner an usw
aber jeden das seine
Und wir warten auf das Logfile.Wir warten
EtreCheck version: 2.8 (240)
Report generated 2016-02-03 08:33:36
Download EtreCheck from http://etrecheck.com
Runtime 4:13
Performance: Good
Click the [Support] links for help with non-Apple products.
Click the [Details] links for more information about that line.
Click the [Check files] link for help with unknown files.
Problem: Other problem
Hardware Information: ⓘ
MacBook Pro (Retina, 15-inch, Mid 2015)
[Technical Specifications] - [User Guide] - [Warranty & Service]
MacBook Pro - model: MacBookPro11,4
1 2,2 GHz Intel Core i7 CPU: 4-core
16 GB RAM Not upgradeable
BANK 0/DIMM0
8 GB DDR3 1600 MHz ok
BANK 1/DIMM0
Bluetooth: Good - Handoff/Airdrop2 supported
Wireless: Unknown Battery: Health = Normal - Cycle count = 32 - SN = D865252Q2SQFWLKA5
Video Information: ⓘ
Intel Iris Pro
Color LCD 2560 x 1600
PL2779Q 2560 x 1440 @ 59 Hz
System Software: ⓘ
OS X El Capitan 10.11.2 (15C50) - Time since boot: less than an hour
Disk Information: ⓘ
APPLE SSD SM0256G disk0 : (251 GB) (Solid State - TRIM: Yes)
EFI (disk0s1) <not mounted> : 210 MB
Recovery HD (disk0s3) <not mounted> [Recovery]: 650 MB
uData (disk0s4) /Users : 175.52 GB (53.97 GB free)
Macintosh HD (disk1) / [Startup]: 74.11 GB (11.21 GB free) (Low!)
Core Storage: disk0s2 74.48 GB Online
USB Information: ⓘ
Apple Inc. Apple Internal Keyboard / Trackpad
Broadcom Corp. Bluetooth USB Host Controller
Burr-Brown from TI USB audio CODEC
Logicool Logicool G430 Gaming Headset
Apple, Inc. Keyboard Hub
Logitech USB Receiver
Apple Inc. Apple Keyboard
Thunderbolt Information: ⓘ
Apple Inc. thunderbolt_bus
Elgato Systems Thunderbolt Dock
Configuration files: ⓘ
/etc/sysctl.conf - File exists but not expected
Gatekeeper: ⓘ
Anywhere
Unknown Files: ⓘ
/Library/LaunchDaemons/com.trendmicro.tmsm.launcher.plist
/Library/LaunchDaemons/com.trendmicro.tmsm.plugin.plist
/Library/LaunchDaemons/at.premedia.weeklymaintenance.plist
/Library/LaunchAgents/com.googlecode.munki.ManagedSoftwareCenter.plist
/Library/LaunchAgents/at.mquadr.agent.3InternetManager.plist
/Library/LaunchDaemons/at.premedia.startupmaintenance.plist
/Library/LaunchDaemons/at.premedia.freemem.plist
7 unknown files found. [Check files]
Kernel Extensions: ⓘ
/Library/Extensions
[loaded] com.logitech.manager.kernel.driver (5.40.1 - SDK 10.8) [Support]
[not loaded] com.mbb.driver.MBBUSBMassStorageDeviceClass (3.7.3 - SDK 10.10) [Support]
/Library/Extensions/HuaweiDataCardDriver_10_9.kext/Contents/PlugIns
[not loaded] com.MBB.driver.MBBACMData (6.00.04 - SDK 10.8) [Support]
[not loaded] com.MBB.driver.MBBActivateDriver (6.00.01 - SDK 10.8) [Support]
[not loaded] com.MBB.driver.MBBEthernetData (6.00.04 - SDK 10.8) [Support]
Startup Items: ⓘ
ciscod: Path: /System/Library/StartupItems/ciscod
Startup items are obsolete in OS X Yosemite
System Launch Agents: ⓘ
[loaded] 155 Apple tasks
[running] 81 Apple tasks
System Launch Daemons: ⓘ
[loaded] 189 Apple tasks
[running] 98 Apple tasks
Launch Agents: ⓘ
[failed] at.mquadr.agent.3InternetManager.plist [Support]
[loaded] com.adobe.AAM.Updater-1.0.plist [Support]
[loaded] com.cisco.anyconnect.gui.plist [Support]
[loaded] com.google.keystone.agent.plist [Support]
[loaded] com.googlecode.munki.ManagedSoftwareCenter.plist [Support]
[loaded] com.googlecode.munki.MunkiStatus.plist [Support]
[loaded] com.googlecode.munki.managedsoftwareupdate-loginwindow.plist [Support]
[running] com.logitech.manager.daemon.plist [Support]
[loaded] com.paragon.updater.plist [Support]
Launch Daemons: ⓘ
[loaded] at.premedia.freemem.plist [Support]
[failed] at.premedia.startupmaintenance.plist [Support]
[loaded] at.premedia.weeklymaintenance.plist [Support]
[loaded] com.adobe.SwitchBoard.plist [Support]
[loaded] com.adobe.agsservice.plist [Support]
[loaded] com.adobe.fpsaud.plist [Support]
[loaded] com.bombich.ccchelper.plist [Support]
[running] com.cisco.anyconnect.vpnagentd.plist [Support]
[loaded] com.google.keystone.daemon.plist [Support]
[loaded] com.googlecode.munki.logouthelper.plist [Support]
[loaded] com.googlecode.munki.managedsoftwareupdate-check.plist [Support]
[loaded] com.googlecode.munki.managedsoftwareupdate-install.plist [Support]
[loaded] com.googlecode.munki.managedsoftwareupdate-manualcheck.plist [Support]
[loaded] com.microsoft.office.licensing.helper.plist [Support]
[loaded] com.skype.skypeinstaller.plist [Support]
[running] com.trendmicro.icore.av.plist [Support]
[running] com.trendmicro.icore.main.plist [Support]
[running] com.trendmicro.icore.wp.plist [Support]
[loaded] com.trendmicro.tmsm.launcher.plist [Support]
[running] com.trendmicro.tmsm.plugin.plist [Support]
User Launch Agents: ⓘ
[loaded] com.citrixonline.GoToMeeting.G2MUpdate.plist [Support]
[failed] com.google.Chrome.framework.plist [Support]
[loaded] com.linotype.FontFolderProtector.plist [Support]
[running] com.spotify.webhelper.plist [Support]
[loaded] com.valvesoftware.steamclean.plist [Support]
User Login Items: ⓘ
FontExplorerXAutoload Programm Hidden (~/Library/Application Support/Linotype/FontExplorer X/FontExplorerXAutoload.app)
iTunesHelper Programm (/Applications/iTunes.app/Contents/MacOS/iTunesHelper.app)
BetterTouchTool Programm (/Applications/BetterTouchTool.app)
Spotify UNKNOWN Hidden (missing value)
Alfred 2 Programm (/Applications/Alfred 2.app)
Android File Transfer Agent Programm (~/Library/Application Support/Google/Android File Transfer/Android File Transfer Agent.app)
MenuMetersApp Programm (~/Library/PreferencePanes/MenuMeters.prefPane/Contents/Resources/MenuMetersApp.app)
EvernoteHelper Programm (/Applications/Evernote.app/Contents/Library/LoginItems/EvernoteHelper.app)
TmLoginMgr Programm (/Library/Application Support/TrendMicro/TmccMac/TmLoginMgr.app)
Other Apps: ⓘ
[running] 2BUA8C4S2C.com.agilebits.onepassword-osx-helper
[running] com.apple.xpc.launchd.oneshot.0x10000002.Display Menu
[running] com.etresoft.EtreCheck.156512
[running] com.evernote.EvernoteHelper.64672
[running] com.google.android.mtpagent.81952
[running] com.hegenberg.BTTRelaunch.72352
[running] com.hegenberg.BetterTouchTool.139872
[running] com.runningwithcrayons.Alfred-2.66912
[running] com.tinyspeck.slackmacgap.19552
[running] com.trendmicro.TM.TmLoginMgr.79712
[running] com.yujitach.MenuMetersApp.126752
[loaded] de.milchimgemuesefach.Display-Menu-Helper
[running] org.mozilla.firefox.82272
Internet Plug-ins: ⓘ
o1dbrowserplugin: Version: 5.41.3.0 - SDK 10.8 [Support]
Default Browser: Version: 601 - SDK 10.11
AdobeExManDetect: Version: AdobeExManDetect 1.1.0.0 - SDK 10.7 [Support]
AdobeAAMDetect: Version: AdobeAAMDetect 1.0.0.0 - SDK 10.6 [Support]
AdobePDFViewerNPAPI: Version: 10.1.16 [Support]
FlashPlayer-10.6: Version: 20.0.0.286 - SDK 10.6 [Support]
Silverlight: Version: 5.1.41212.0 - SDK 10.6 [Support]
QuickTime Plugin: Version: 7.7.3
Flash Player: Version: 20.0.0.286 - SDK 10.6 [Support]
googletalkbrowserplugin: Version: 5.41.3.0 - SDK 10.8 [Support]
SharePointBrowserPlugin: Version: 14.5.7 - SDK 10.6 [Support]
AdobePDFViewer: Version: 10.1.16 [Support]
JavaAppletPlugin: Version: 15.0.1 - SDK 10.11 Check version
User internet Plug-ins: ⓘ
CitrixOnlineWebDeploymentPlugin: Version: 1.0.105 [Support]
WebEx64: Version: 1.0 - SDK 10.6 [Support]
Safari Extensions: ⓘ
1Password
AdBlock
statusbar-lite
Server Switcher
Firebug Lite for Safari
3rd Party Preference Panes: ⓘ
Flash Player [Support]
Logi Options Launcher [Support]
MenuMeters [Support]
Paragon NTFS for Mac ® OS X [Support]
Time Machine: ⓘ
Skip System Files: NO
Auto backup: YES
Volumes being backed up:
Macintosh HD: Disk size: 74.11 GB Disk used: 62.90 GB
Destinations:
Backup [Local]
Total size: 300.13 GB
Total number of backups: 7
Oldest backup: 19.01.16, 07:58
Last backup: 19.01.16, 16:39
Size of backup disk: Excellent
Backup size 300.13 GB > (Disk size 74.11 GB X 3)
Top Processes by CPU: ⓘ
27% kextd
20% firefox
18% ocspd
14% Mail
8% WindowServer
Top Processes by Memory: ⓘ
1.13 GB kernel_task
672 MB firefox
442 MB mds_stores
377 MB Slack
229 MB mdworker(13)
Virtual Memory Information: ⓘ
9.24 GB Free RAM
6.75 GB Used RAM (3.54 GB Cached)
0 B Swap Used
Diagnostics Information: ⓘ
Feb 3, 2016, 08:25:24 AM ~/Library/Logs/DiagnosticReports/CalendarAgent_2016-02-03-082524_[redacted].crash
/System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
Feb 3, 2016, 08:25:24 AM ~/Library/Logs/DiagnosticReports/gamed_2016-02-03-082524_[redacted].crash
/System/Library/PrivateFrameworks/GameCenterFoundation.framework/Versions/A/gamed
Feb 3, 2016, 08:25:22 AM ~/Library/Logs/DiagnosticReports/IMRemoteURLConnectionAgent_2016-02-03-082522_[redacted].crash
/System/Library/PrivateFrameworks/IMFoundation.framework/XPCServices/IMRemoteURLConnectionAgent.xpc/Contents/MacOS/IMRemoteURLConnectionAgent
Feb 3, 2016, 08:24:27 AM ~/Library/Logs/DiagnosticReports/com.apple.lakitu_2016-02-03-082427_[redacted].crash
/System/Library/PrivateFrameworks/CloudServices.framework/Versions/A/Frameworks/EscrowService.framework/Versions/A/XPCServices/com.apple.lakitu.xpc/Contents/MacOS/com.apple.lakitu
Feb 3, 2016, 08:24:25 AM ~/Library/Logs/DiagnosticReports/nsurlsessiond_2016-02-03-082425_[redacted].crash
/usr/libexec/nsurlsessiond
Feb 3, 2016, 08:24:24 AM /Library/Logs/DiagnosticReports/securityd_2016-02-03-082424_[redacted].crash
/usr/sbin/securityd
Feb 3, 2016, 08:08:55 AM Self test - passed
Feb 3, 2016, 04:04:29 AM /Library/Logs/DiagnosticReports/mdmclient_2016-02-03-040429_[redacted].crash
/usr/libexec/mdmclient
Feb 3, 2016, 12:00:55 AM /Library/Logs/DiagnosticReports/mdmclient_2016-02-03-000055_[redacted].crash
Feb 2, 2016, 06:15:05 PM ~/Library/Logs/DiagnosticReports/EvernoteHelper_2016-02-02-181505_[redacted].crash
com.evernote.EvernoteHelper - /Applications/Evernote.app/Contents/Library/LoginItems/EvernoteHelper.app/Contents/MacOS/EvernoteHelper
Feb 2, 2016, 04:32:03 PM ~/Library/Logs/DiagnosticReports/CalendarAgent_2016-02-02-163203_[redacted].crash
Feb 2, 2016, 02:26:19 PM ~/Library/Logs/DiagnosticReports/CalendarAgent_2016-02-02-142619_[redacted].crash
Feb 2, 2016, 01:21:32 PM ~/Library/Logs/DiagnosticReports/Microsoft Excel_2016-02-02-132132_[redacted].crash
com.microsoft.Excel - /Applications/Microsoft Office 2011/Microsoft Excel.app/Contents/MacOS/Microsoft Excel
Feb 2, 2016, 07:22:30 AM ~/Library/Logs/DiagnosticReports/EvernoteHelper_2016-02-02-072230_[redacted].crash
Feb 2, 2016, 06:38:19 AM /Library/Logs/DiagnosticReports/iTunes_2016-02-02-063819_[redacted].hang
Feb 1, 2016, 04:36:18 PM ~/Library/Logs/DiagnosticReports/EvernoteHelper_2016-02-01-163618_[redacted].crash
Feb 1, 2016, 12:47:32 PM ~/Library/Logs/DiagnosticReports/JavaApplicationStub_2016-02-01-124732_[redacted].crash
com.install4j.5517-2803-0637-4585.64 - /Applications/SoapUI-5.2.1.app/Contents/MacOS/JavaApplicationStub
Feb 1, 2016, 12:46:41 PM ~/Library/Logs/DiagnosticReports/JavaApplicationStub_2016-02-01-124641_[redacted].crash
Feb 1, 2016, 12:45:54 PM ~/Library/Logs/DiagnosticReports/JavaApplicationStub_2016-02-01-124554_[redacted].crash
Feb 1, 2016, 12:45:42 PM ~/Library/Logs/DiagnosticReports/JavaApplicationStub_2016-02-01-124542_[redacted].crash
Feb 1, 2016, 12:30:48 PM ~/Library/Logs/DiagnosticReports/iTunes_2016-02-01-123048_[redacted].crash
Feb 1, 2016, 09:06:02 AM ~/Library/Logs/DiagnosticReports/CalendarAgent_2016-02-01-090602_[redacted].crash
Feb 1, 2016, 08:35:53 AM ~/Library/Logs/DiagnosticReports/EvernoteHelper_2016-02-01-083553_[redacted].crash
Feb 1, 2016, 08:21:47 AM ~/Library/Logs/DiagnosticReports/EvernoteHelper_2016-02-01-082147_[redacted].crash
Feb 1, 2016, 06:55:45 AM ~/Library/Logs/DiagnosticReports/gamed_2016-02-01-065545_[redacted].crash
Feb 1, 2016, 06:55:21 AM ~/Library/Logs/DiagnosticReports/IMRemoteURLConnectionAgent_2016-02-01-065521_[redacted].crash
Feb 1, 2016, 06:55:05 AM /Library/Logs/DiagnosticReports/apsd_2016-02-01-065505_[redacted].crash
/System/Library/PrivateFrameworks/ApplePushService.framework/apsd
Feb 1, 2016, 06:54:51 AM ~/Library/Logs/DiagnosticReports/accountsd_2016-02-01-065451_[redacted].crash
/System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
Feb 1, 2016, 06:54:49 AM ~/Library/Logs/DiagnosticReports/nsurlsessiond_2016-02-01-065449_[redacted].crash
Feb 1, 2016, 06:54:48 AM /Library/Logs/DiagnosticReports/securityd_2016-02-01-065448_[redacted].crash
