ich wollte mir via port lame installieren.
dabei stieß er auf die abhängigkeit mit ncurses(-w) und will dieses natürlich auhc direkt installieren. Ich denke mir ok, mach mal ...
und jetzt?
was kann ich tun, damit er es installiert bekommt?
Mir ist zudem aufgefallen, dass die datei "/opt/local/lib/libformw.5.dylib" nicht existiert. hat die zufällig jemand?
Code:
---> Building ncursesw with target all
Error: Target com.apple.build returned: shell command "cd "/opt/local/var/db/dports/build/_opt_local_var_db_dports_sources_rsync.rsync.darwinports.org_dpupdate_dports_devel_ncursesw/work/ncurses-5.6" && make all" returned error 2
Command output: /usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o hashtest ../obj_s/hashtest.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o ins_wide ../obj_s/ins_wide.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o inserts ../obj_s/inserts.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o keynames ../obj_s/keynames.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o knight ../obj_s/knight.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o lrtest ../obj_s/lrtest.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o movewindow ../obj_s/movewindow.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o ncurses ../obj_s/ncurses.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic -L../lib -lformw -lmenuw -lpanelw -lncursesw
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o newdemo ../obj_s/newdemo.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o railroad ../obj_s/railroad.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic -L../lib -lncursesw
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o rain ../obj_s/rain.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o redraw ../obj_s/redraw.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o savescreen ../obj_s/savescreen.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o tclock ../obj_s/tclock.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o testaddch ../obj_s/testaddch.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o testcurs ../obj_s/testcurs.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o testscanw ../obj_s/testscanw.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o view ../obj_s/view.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o worm ../obj_s/worm.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
/usr/bin/gcc-4.0 -O2 -no-cpp-precomp -no-cpp-precomp -o xmas ../obj_s/xmas.o -Wl,-search_paths_first -I../test -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -no-cpp-precomp -no-cpp-precomp -dynamic `echo "-L../lib -lformw -lmenuw -lpanelw -lncursesw " | sed -e 's/-lform.*-lpanel[^ ]*//'`
cd misc && make DESTDIR="" all
make[1]: Nothing to be done for `all'.
cd c++ && make DESTDIR="" all
/usr/bin/g++-4.0 -o demo ../obj_s/demo.o -L../lib -lncurses++w -L../lib -lformw -lmenuw -lpanelw -lncursesw -Wl,-search_paths_first -I../c++ -I../include -I. -DHAVE_CONFIG_H -I. -I../include -U_XOPEN_SOURCE -D_XOPEN_SOURCE=500 -DSIGWINCH=28 -D_XOPEN_SOURCE_EXTENDED -DNDEBUG -I/opt/local/include/ncursesw -O2 -dynamic
/usr/bin/ld: warning prebinding disabled because dependent library: /opt/local/lib/libformw.5.dylib is not prebound
/usr/bin/ld: Undefined symbols:
___dso_handle
collect2: ld returned 1 exit status
make[1]: *** [demo] Error 1
make: *** [all] Error 2
Error: The following dependencies failed to build: ncursesw
Error: Status 1 encountered during processing.
und jetzt?
