Sagt die Konsole was dazu?
Ja und gibt es dazu einen Bericht/ oder log Eintrag?
Das ist gut, oder auch nicht.Jede Menge Einträge
Was heisst mehrere 20? Mehrere oder 20? Oder das Mehrfache von 20?Das sind mehrere 20
Das taucht bei jedem Start auf. Auch nach Ruhezustand.
19.08.15 20:38:59,972 distnoted[214]: # distnote server agent absolute time: 6.054212394 civil time: Wed Aug 19 20:38:59 2015 pid: 214 uid: 501 root: no
19.08.15 20:39:00,675 ReportPanic[227]: Failed to connect (panicHeaderLabel) outlet from (ReportPanicAppDelegate) to (NSTextField): missing setter or instance variable
19.08.15 20:39:00,675 ReportPanic[227]: Failed to connect (panicMessageLabel) outlet from (ReportPanicAppDelegate) to (NSTextField): missing setter or instance variable
19.08.15 20:39:00,676 ReportPanic[227]: Failed to connect (reportButton) outlet from (ReportPanicAppDelegate) to (NSButton): missing setter or instance variable
19.08.15 20:39:00,678 ReportPanic[227]: ReportPanic could not stat /Library/Logs/DiagnosticReports/Kernel_2015-08-14-180018_Julians-MacBook-Pro.panic
19.08.15 20:39:00,796 fmfd[241]: Initialized sandbox
19.08.15 20:39:01,098 pboard[253]: Attempt to unlink previous shared memory during startup returned an error. Continuing...
19.08.15 20:39:01,382 com.apple.internetaccounts[251]: Additional Logging , array retured in signedInAccounts is (
"<IAAccount: 0x6080000570d0> -- uid: 514BA135-1789-469F-866F-71FEB3551D50; loginName: [email protected]; provider: com.apple.account.icloud; parent: (null)\n\taccount ID: [email protected] - com.apple.account.icloud - \n\tprovider attrs: {\n IADSIDKey = 1062371899;\n accountDescription = iCloud;\n \"com.apple.InternetAccounts.loginName\" = \"[email protected]\";\n \"com.apple.InternetAccounts.provider\" = \"com.apple.account.icloud\";\n fullName = iCloud;\n}"
19.08.15 20:39:01,450 com.apple.internetaccounts[251]: Returning accountUIDs: (
19.08.15 20:39:01,450 com.apple.internetaccounts[251]: Adding listener
19.08.15 20:39:02,218 com.apple.iCloudHelper[248]: AOSKit ERROR: Storage usage request failed, [email protected], url=https://p04-quota.icloud.com:443/quotaservice/external/osx/1062371899/storageUsageInfo, requestHeaders=
"Accept-Language" = "de-de";
Authorization = "...";
"X-Mme-Client-Info" = "<MacBookPro11,1> <Mac OS X;10.10.5;14F27> <com.apple.AOSKit/217 (com.apple.CloudPhotosConfiguration/1.0.1)>";
"X-Mme-Country" = DE;
"X-Mme-Device-Id" = "D804C952-92FF-5495-B235-78F614AA6FD2";
"X-Mme-Timezone" = MESZ;
error=Error Domain=AOSErrorDomain Code=1000 "Der Vorgang konnte nicht abgeschlossen werden. (AOSErrorDomain-Fehler 1000.)" UserInfo=0x7f95d3c2ded0 {UnderlyingError=Es besteht anscheinend keine Verbindung zum Internet., DialogInfo={
DialogType = Unknown;
}}, httpStatusCode=-1
19.08.15 20:39:02,221 com.apple.CloudPhotosConfiguration[263]: [AOSAccounts] : [MMRetrieveQuotaUsage] : account [email protected] _AOSAccountRetrieveStorageUsageInfo failed with error Der Vorgang konnte nicht abgeschlossen werden. (AOSErrorDomain-Fehler 1000.) and reason (null) domain AOSErrorDomain
19.08.15 20:39:02,394 com.apple.iCloudHelper[248]: AOSKit ERROR: ([email protected]) Ramp state request failed, url=https://p04-availability.icloud.com:443/1062371899/sharedstreams/status?feature=photos, requestHeaders=
error=Error Domain=AOSErrorDomain Code=1000 "Der Vorgang konnte nicht abgeschlossen werden. (AOSErrorDomain-Fehler 1000.)" UserInfo=0x7f95d3d02150 {UnderlyingError=Es besteht anscheinend keine Verbindung zum Internet., DialogInfo={
Wie kann man die denn prüfen? Rausnehmen und die Spannung messen wäre ja sehr aufwendig, da müsste der ganze Rechner auseinandergebaut werden. Im Systemprofiler habe ich da auch nichts gefunden.Ist die eingebaute Batterie (nicht der Akku, falls das ein mobiles System sein sollte!) in Ordnung?
Ja, aber nach einem Neustart kann man anhand der Uhrzeiten auswählen, was relevant sein könnte. Wenn das Fenster aufspringt, wird doch sicher kurz davor ein Eintrag im Log erfolgen.Das mit den Log-Einträgen ergibt keinen Sinn. Das Konsolfenster enthält unter normalen Umständen immer 4.000 Einträge.
